where is my rotor supposed to be at TDC
Old Apr 29, 2005 | 07:07 PM
SUTTERERMAN85's Avatar
can some one tell me where the rotor is supposed to be pointing at when the engine is at TDC? my opti has a master spline and the shaft on the cam gear doesnt? my car runs but it back fires through the intake during WOT. could this be a bad opti? please let me know what you guys think. thanks
nick
Old Apr 29, 2005 | 09:21 PM
93fblt1's Avatar
Re: where is my rotor supposed to be at TDC
I am currently putting opti back together after cam swapped. I think it should be pointing at 1pm position or toward number one cylinder.
Old Apr 29, 2005 | 09:48 PM
firetird's Avatar
a bad opti can make your car backfire at WOT but i dont think you would be able to start your car if the opti wasnt aligned properly.
Old Apr 29, 2005 | 10:42 PM
ok thanks for the help guys
Old Apr 29, 2005 | 11:36 PM
Alvin@pcmforless.com's Avatar
Cam installed dot to dot?
Old Apr 30, 2005 | 10:14 AM
i am not sure . i already had the timming cover on. the #1 piston is at TDC and the intake valve has just closed. the rotor should be at the #1 pin on the cap, i think at the 7:00 position.
Old Apr 30, 2005 | 10:12 PM
...might be a little closer to 6:30 ...
Old May 2, 2005 | 05:39 PM
93fblt1's Avatar
Which end pointing at 6:30? My rotor wide end is pointing at 6:30 and smaller end at 1. Engine seems to run okay. Little rough idle but no miss. I am waiting for new chip to smooth out the idle.
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
jayblev95
Sep 26, 2015 09:44 PM
350350
14
Aug 11, 2015 12:03 PM
