I'm doing seafoam, need help quick
Old Mar 9, 2008 | 01:19 PM
z28rider78's Avatar
The directions say:
seafoam deep creep is to be sprayed inside your throttle body. disconnect your hose running to the throttle body so your throttle body blade is showing.
My question, i dont want to do it wrong. Can someone show me a picture of this hose so i dont **** up my car please I think i'm about to do the wrong thing
Thx,
Old Mar 9, 2008 | 01:21 PM
cvccbum's Avatar
It's not really a hose. You take off the intake elbow. It's the big thing in front of the throttle body.
Good luck!
Old Mar 9, 2008 | 01:47 PM
And if you want the engine to run with the intake elbow and MAF not connected to the throttle body, unplug the MAF sensor so the PCM defaults to speed-density mode.
Shoebox has what you need:
http://shbox.com/1/devices.htm
The part with the "G" on it ("G" is the IAT sensor, but its pushed into the intake elbow) will be what you remove. Part "N" is the MAF sensor that you need to unplug.
Why do you feel you need to "Seafoam" the engine"?
Old Mar 9, 2008 | 01:57 PM
z28rider78's Avatar
Good luck!
Lol, i thought thats what they meant. Just kind of threw me off when they said "hose"
Thanks for the clarification fellaz
Old Mar 9, 2008 | 01:59 PM
z28rider78's Avatar
Because i believe in fairy tales
I dont know, the writeup on this link kind of convinced me to give it a shot.
http://www.ls1tech.com/forums/showth...hlight=seafoam
Old Mar 9, 2008 | 02:26 PM
Dave1980's Avatar
did it on my dads explorer, a few weeks later and got o2 codes. Coincidence? I have no idea, but I will not do it again.
Old Mar 9, 2008 | 02:31 PM
My Red 93Z-28's Avatar
I'm guessing the carbon that you broke up went out the exhaust and screwed up your O2's
Old Mar 9, 2008 | 07:00 PM
z28rider78's Avatar
Did my seafoam. Lots of smoke & fun. Car is running better. Smoother idle, better throttle response on top end. Didnt fix my miss so still some more work to be done. Time to start another "help me fix it" thread
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
