I'm doing seafoam, need help quick
The directions say:
seafoam deep creep is to be sprayed inside your throttle body. disconnect your hose running to the throttle body so your throttle body blade is showing.
My question, i dont want to do it wrong. Can someone show me a picture of this hose so i dont **** up my car please
I think i'm about to do the wrong thing
Thx,
Thx,
And if you want the engine to run with the intake elbow and MAF not connected to the throttle body, unplug the MAF sensor so the PCM defaults to speed-density mode.
Shoebox has what you need:
http://shbox.com/1/devices.htm
The part with the "G" on it ("G" is the IAT sensor, but its pushed into the intake elbow) will be what you remove. Part "N" is the MAF sensor that you need to unplug.
Why do you feel you need to "Seafoam" the engine"?
Because i believe in fairy tales
I dont know, the writeup on this link kind of convinced me to give it a shot.
http://www.ls1tech.com/forums/showth...hlight=seafoam
Did my seafoam. Lots of smoke & fun.
Car is running better. Smoother idle, better throttle response on top end. Didnt fix my miss so still some more work to be done. Time to start another "help me fix it" thread
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
