Ignition Fuse problem
Old Jun 25, 2006 | 10:01 AM
alkalinekid's Avatar
Well last year our ignition fuse blew a couple times...i don't remember what our mechanic did but we fixed it. Now it's doing it again, it'll drive fine for 20mns then all of a sudden the car will die and the fuse is blown. My neighbor (a mechanic), said we could try putting a 15amp instead of a 10amp in the fuse.
Think that will make a difference?
Old Jun 25, 2006 | 10:08 AM
red 95 z28 lt1's Avatar
Re: Ignition Fuse problem
i wouldent reccomend doing that, it could cause a fire, there may be a something loose or a hot wire intermitanly grounding itself out, find the problem and fix it the right way. a 15 amp fuse is just a temporary fix
Old Jun 25, 2006 | 10:35 AM
BlackDog's Avatar
You may have cut open the wire harness and trace the wires all the way back to the PCM. Sometimes the wires within the harness stick together from age and heat. It's a slow process but has to be done.
Old Jun 25, 2006 | 11:54 AM
Don't substiture a larger fuse unless you really want wiring problems. Trace out the pink wire to the coil and ICM to be sure it is in good shape.
Old Jun 25, 2006 | 04:35 PM
BIG SHAFE's Avatar
I have the LTCC setup and they suggest using larger amp ratings without there being any trouble. Is this a bad idea?
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
eanhl2004
Apr 4, 2015 12:01 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
