ignition coil or optispark
Old Nov 27, 2003 | 10:26 AM
wesley jones's Avatar
Question ignition coil or optispark
Is there any wat to test the ignition coil to see if it is malfunctioning or a test for the optispark . Ihave an 95 ta lt1 motor will not start. note the motor does turn over. Any volt /ohm meter test to check thanks wes .
Old Nov 27, 2003 | 11:46 AM
When you say "turn over", what do you mean? It means starter not cranking to me and that would have nothing to do with coil or opti.
If you mean it cranks, but does not start, check for spark. There are some tests for coil and opti on my Tech Page.
Old Nov 27, 2003 | 02:55 PM
coil and opti
Yes i mean it cranks but will not start , i will check out the tech page
Old Nov 27, 2003 | 04:04 PM
jasons93z's Avatar
Pull the plugs and check for spark.
Old Nov 29, 2003 | 10:00 AM
anything else to check
Old Nov 29, 2003 | 12:07 PM
Jeff H's Avatar
Listen to make sure the fuel pump is running when you first turn the key to the "on" position. Check your fuel pump fuse to see if it's blown. Sounds like you're not getting spark or fuel.
Old Nov 30, 2003 | 05:53 PM
Ok i tested the coil and it shows the coil is good ,i tested the connectors for voltage to the pink wire and its ok . I had someone to start the car while checking the sparkplug wire for arcing no spark or arcing at all fuel pump is working gas is getting to cylinder i dont know whats left ? is there any test for the optispark ? thanks wes
markzzzz
Aug 17, 2015 11:08 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Cam28_boy
Aug 6, 2002 08:40 AM
Scottysta
Aug 1, 2002 08:21 AM
