Zaino
Old Jul 31, 2002 | 06:48 PM
Scottysta's Avatar
Post Zaino
I'm wondering if i can put Z5 on top of Z2 or do i have to buff off the Z1-Z2 before i can put on the Z5? Sorry first time i am putting on Zaino!
Thanks for any help!!!
Scott
95 Trans Am
JBA headers,comp 1.6RR,"305"comp cam,TB Bypass,Cutout,Meziere WP,Strut Tower,373,2100 stall,Trans Go,PP3,160 stat,cold air,adj.fuel reg,dual springs,air temp module,ignition coil,8.5mm wires,airfoil,ported ends
Old Jul 31, 2002 | 07:29 PM
Wildcat's Avatar
Post
You should remove the Z-1/Z-2 before you apply the Z-5. For optimal results, use the Z-6 gloss enhancer after each coat of Zaino.
Old Jul 31, 2002 | 07:32 PM
MikeLS's Avatar
Thumbs up
I second what Wildcat said above...he's right on!
Also, you need to allow at least at least 6 hours before you apply another coat of Zaino, when using the Z1 route.
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
Show Car Shine by ZAINO! - Special Thanks to Sal Z!
Old Jul 31, 2002 | 08:01 PM
Z284ever's Avatar
Post
According to Zaino....Z2 and Z5 can be used interchangeably. What gives?
Old Jul 31, 2002 | 08:11 PM
Kevin V 2002 SS's Avatar
Post
Interchangeable means 2 coats Z-5, 1 coat Z-2, 1 coat Z-5, 3 coats Z-2......, buffing off each coat and then adding the next coat.
It doesn't mean applying a coat of Z-2 or Z-5 on top of each other without buffing off the previous coat first, you wouldn't have accomplished anything.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
Old Jul 31, 2002 | 08:16 PM
Z284ever's Avatar
Post
Sorry...misunderstood. I thought you guys were saying buff off...as in remove previuos coat with an abrasive polish.
Old Aug 1, 2002 | 07:39 AM
Scottysta's Avatar
Post
OK, Thanks for the Info,But i have 1 more thing i misunderstood. I applyed the Z2 right after(about 45minutes-hour)i put on the Z1, someone said to let it stay on for 6 hours,is it the same with the Z2 on top??? The Z1-Z2 is still on the car right now and was going to leave on the car for 36 hours is this ok????? thanks guys
[This message has been edited by Scottysta (edited August 01, 2002).]
Old Aug 1, 2002 | 08:21 AM
KevinSS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Scottysta:
Nope, you do not have to wait at all before applying Z-2 or Z-5 on top of the Z-1. Z-1 is ready for 2 or 5 as soon as it is rubbed into the paint
The 6 hours is how long it takes a polish layer (after you have buffed off the residue) to cure on the paint to be ready for another layer of Zaino (when using the Z-1 system, no wait required for ZFX system) so the polish layers will build.
See Above
Yes, as long as it is in a covered garage with no dust. Properly applied the Z-1 and Z-2 should both dry in under an hour easy.
thanks guys
</font>
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
ChrisFrez
Mar 29, 2015 09:43 PM
stavos
Jul 22, 2002 10:21 PM
squirrels
Sep 24, 2001 02:31 PM
klaymon
21
Sep 19, 2001 11:11 AM
Lt1Diablo
Sep 14, 2001 12:47 AM
