Idle very high
Idle very high
I recently replaced my iac valve, but anyways within the past week i had a big coolant leak that has been fixed, now my idle is super high. 1500 in neutral or park. It drops a little when in drive to about 1000. I am not getting any ses lights so i assume everything is still plugged in.
What do you think is wrong, was it a moisture problem. My opti got a little wet but its not missfiring at all. I would assume that the tps and iac valve got wet. What should i try to do?
Re: Idle very high
check for vacume leaks and put a scanner on it and read all the sensors and make sure they are within there limits, you may have a hidden code, also check tps sensor i had a simmilar problem with the idle and it was the tps sensor
ChrisFrez
Mar 1, 2015 01:33 PM
