Idle very high
Old Dec 19, 2005 | 05:12 PM
pHEnomIC's Avatar
Idle very high
I recently replaced my iac valve, but anyways within the past week i had a big coolant leak that has been fixed, now my idle is super high. 1500 in neutral or park. It drops a little when in drive to about 1000. I am not getting any ses lights so i assume everything is still plugged in.
What do you think is wrong, was it a moisture problem. My opti got a little wet but its not missfiring at all. I would assume that the tps and iac valve got wet. What should i try to do?
Old Dec 19, 2005 | 06:04 PM
red 95 z28 lt1's Avatar
Re: Idle very high
check for vacume leaks and put a scanner on it and read all the sensors and make sure they are within there limits, you may have a hidden code, also check tps sensor i had a simmilar problem with the idle and it was the tps sensor
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
