IAT Sensor question???
Old Apr 6, 2007 | 10:49 AM
  #16
JSK333's Avatar
Originally Posted by evilundisguised
At the very least, there is a table relating IAT to spark advance (in the LT1 PCM).
Sure you're not thinking of coolant temp spark correction? In my PCM_EE definition file version BZ, in TunerCat, I see no tables including IAT--only coolant temp.
Old Apr 6, 2007 | 11:23 AM
  #17
evilundisguised's Avatar
Is that an OBDI file? Mine's OBDII, maybe that's the difference.
I definitely have a "Spark advance correction vs IAT vs MAP" table in there.
Old Apr 8, 2007 | 11:04 AM
  #18
DAFAIC's Avatar
Is there a way to test to see what it is really reading? 10 year old sensor may not be working as good as it was new?
Old Apr 8, 2007 | 11:44 AM
  #19
The temp sensor is a thermistor... the resistance varies inversely with temperature. With the harness connector removed, measure the resistance, and see if it is close to the value in the table of resistance vs. temp (for the actual ambient air temp). I think Shoebox has the table on his "how to test the sensor" writeup. If not, I have the table in my online scanner writeup:
http://members.aol.com/InjuneerZZ/ScanMast.htm
If you pull the sensor out, put it in ice water and see if it reads about 9,420 ohms, then put it in boiling water and see if it reads about 177 ohms (sea level only, at higher altitudes it will read a bit higher).
Old Apr 8, 2007 | 12:44 PM
  #20
JSK333's Avatar
Either that's it or TunerCat hasn't added the table in the OBDI definition yet. Interesting!
Old Apr 8, 2007 | 05:09 PM
  #21
DAFAIC's Avatar
Thanks a bunch...
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Feb 13, 2015 03:09 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
