IAT Sensor question???
Old Mar 14, 2007 | 09:54 PM
94_camm's Avatar
Do i need the IAT(Intake Air Temp)sensor?Just finishing up my 383 and thats the only sensor i dont have!....94 lt1 camaro...
Old Mar 14, 2007 | 10:03 PM
LiENUS's Avatar
Yes you do, It's quite important.
Old Mar 14, 2007 | 10:37 PM
The computer really likes to have all the sensor inputs, so your engine can run correctly.
Old Mar 14, 2007 | 11:07 PM
LiENUS's Avatar
I don't even think the IAT can be (sanely) tuned out.
Old Apr 5, 2007 | 07:24 AM
KSSS's Avatar
anyone know how much a new one is? I just got a SES light for the IAT. How far down does it go(the other end you cant see)? Does it plug in somewhere under the intake elbow?
Old Apr 5, 2007 | 07:42 AM
guywithaZ's Avatar
I forgot to plug mine in once and it got chewed up by the engine because it was dangling there. Can't say as though I really noticed it was gone, IIRC the check engine light came on but I didn't notice a drivability problem.
Old Apr 5, 2007 | 08:40 AM
transAMdriv3r's Avatar
they are pretty cheap at only 15 bucks at most. yes it is the only sensor on the elbow.
Old Apr 5, 2007 | 09:08 AM
KSSS's Avatar
It started throwing codes after my last K&N recharge. Perhaps I used to much oil and it gummed up the sensor?
I reset the SES light, im gonna wait till it comes back on. Hopefully this is the only code its throwing. If it comes back IAT, i will replace it.
Old Apr 5, 2007 | 05:37 PM
You can't "gum up the sensor". Its a variable resistor (thremistor) encased in a housing. The SES light will only come on if the indicated inlet air temp is irrationally high or low (circuit voltage under 0.46V or over 4.96V).
Old Apr 5, 2007 | 07:05 PM
JSK333's Avatar
Has anyone verified what affect it has on the PCM in MAF sensor cars?
Old Apr 5, 2007 | 07:25 PM
evilundisguised's Avatar
At the very least, there is a table relating IAT to spark advance (in the LT1 PCM).
Old Apr 5, 2007 | 07:40 PM
30th6's Avatar
ive been spraying a 150 wet shot of n20 across mine for 2 years and no problems yet.
Old Apr 5, 2007 | 08:01 PM
InsuranceGuy's Avatar
Mine went out and my datamaster was reading negative
130 degree temps. Naturally at those temps, my PCM
was flooding my motor with fuel.
Emil:93Z,Vortech,NOS
Old Apr 5, 2007 | 09:59 PM
It would only affect fueling in a speed-density 93, as you have... would not do the same on the MAF engines. The default reading in the ECM for an open circuit is typically -40degF. Never saw one read lower than that.
Old Apr 6, 2007 | 09:52 AM
You're right. I looked back thru my old datalogs and it was
actually -36.4. It was indicating this temp in both open loop and
closed loop. When it would go into closed loop it would almost
stall the motor out with all the excess fuel.
