iat relocation?
Old Sep 11, 2004 | 09:55 AM
  #31
Re: iat relocation?
Originally Posted by 94bird
Thanks for doing the experiments Injuneer. How much difference in IAT from the sensor vs. your thermocouple did you see? I'm curious how heat soaked you found the sensor to be. I have never found this to be an issue in any other car, even when running hot tests in Vegas or Arizona in the summer.
I can't remember the details.... the stock engine/Honker CAI came out of my car in 1999. I think there was at least a 20degF difference between the IAT reading and the temperature measured right in front of the TB (through the hole drilled in the elbow for my dry nitrous nozzle) with a Radio Shack remote temp sensor - yes I sealed around the wire to prevent cold air from entering the hole in the elbow. At the time, my underhood temps seemed extremely excessive, running a set of coated JBA headers. It wasn't as bad before the headers. I even pulled the gasket off that seals the hood to the cowl to help get the heat out - not recommended for wet climates.
RUENUF
Mar 13, 2016 03:37 PM
Devinfoote87
Feb 12, 2016 03:21 PM
Girrrrl
Aug 20, 2015 09:26 AM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
