iat relocation?
iat relocation?
i think this is the last free mod i can do!
so my ? is where to put it? and do i have to buy longer wires?
do i put it as close to the k&n as possible?
it looks to me that the stock wires can be run around to be made long enough to get a few inches from the filter! do u think it is possible? well thanks in advance and all suggestions will be helpful
so my ? is where to put it? and do i have to buy longer wires?do i put it as close to the k&n as possible?
Re: iat relocation?
Originally Posted by blazer_4.3
TTT then y do people do it? i kno wit is no ta noticeable gain but it has to help a lil right? please answer!
Re: iat relocation?
Having looked at programming tables on a MAF engine, I truthfully cannot figure out what real effect the IAT has. Unless I missed some, I find no tables regarding the IAT. In the past, I have read that the PCM uses the MAF to calculate air temp. So, I have no real proof that altering the IAT readings does anything at all. Maybe there is some truthful info out there, somewhere. I would personally need more info/understanding before I bothered to change anything. A lot of lemmings have jumped off the f-body cliff.
Re: iat relocation?
I'd agree that relocating it would probably help, if you've ever watched a scanner while in traffic you'll see it shoot WAY up. Perhaps its in my head but i swear i notice a difference lol. It would probably wake the car up a tad after sitting in one spot for a while and the air really isn't as warm as the sensor is reporting.
Re: iat relocation?
It will help, mostly in the summertime sitting in traffic. Mine heated up to 145* sitting in traffic. If you do it you can't change the resistance in the curciut, because the iat is a resistance sensor like a coolant temp. sensor. Make sure that you use the same guage wire when running wires to the airfilter or whatever.
Re: iat relocation?
Originally Posted by toby360
I've seen (and am sure you have too) a bunch of posts with people having some pretty bad stumbles relating to their IAT gone bad (reporting -40 degrees). So i'm sure it does something, I'm hoping to get tuner CATS soon to look at the tables as well... Also, just because its not in a tuning program doesnt mean its not in the computer, it might not have been mapped yet (unless they claim all variables in the computer are available).
All I was saying was I had not seen any proof of what it does. I did not claim it did nothing.
I also have not seen any data on how it helps to relocate it, either. Again, not saying relocating does nothing. Just no data for me to tell either way.
Re: iat relocation?
I thought the pcm uses the IAT value when determining air fuel mix. When the IAT reads high temps. the pcm pulls alittle fuel due to less dense air when its hot outside. When the IAT reads coldier temps it adds fuel because of the denser ambient air? I could be wrong tough maybe madwolf can tell if the IAT value is even a factor in programming, I'm guessing it does.
Re: iat relocation?
I bypassed my IAT with a 4.7k resistor. Just unplug the sensor and plug the resistor right into the connector and wrap it with electrical tape. It has been beneficial for me. It solved an intermittent vibration problem I was having. I cant claim that I got any horsepower out of it but it certainly didnt hurt. I know my car runs smoother with it bypassed.
Re: iat relocation?
Warm the engine up...
Try looking at the Injector PW and MAF table, plug the IAT hole, then put the IAT right against a hot coolant tube. That should heat it up significantly. Make note of this point in some logs.
Then do the same thing but put a plastic bag around it and submerse it in some cold water... Make not of this point in the logs too.
Throw it into excel and compare the two sections, if the MAF G/s is the same and the PW have changed noticably we know that it should be due to the temp sensor since thats the only variable thats changed.
I'm curious as to how much it affects it all. Theoretically, if there was a change we could ballpark the equation it applies at that RPM...
Maybe i'll do this with freescan when i have a bit of time
