IAC OHM'd readings bad
I just tested mine and the AtoB terminals read OL and the CtoD termianl reads 55 ohms, will this cause a bad idle, if it idles at all?
http://shbox.com/1/iac2.jpg
I did, and I even used my IAC tester with wires hanging out and checked it in line. I even cleaned the terminals, and verified that the wires going in there were the same colors. It was bad.
I installed a new one yesterday, and voila, the idle is doing great. It hasnt done this in years where the idle actually moves around as commanded by the ecm.
I am going to drive it around for a while today and get the IAC familiar with the engine needs. I did th IAC reset like your site says shoebox, and she is doing good.
I just cant understand why I never had a code. And after all these years of trying to figure out my idle issue.
No fuel smell either.
z28projects4ever
9
Jul 16, 2002 07:48 PM
