I think i may have a factory FREAK
Old Aug 14, 2003 | 10:46 PM
  #31
blueirocz-28's Avatar
that would be a case of you knowing how to drive your car better than your friend. ls1's have tons of power, not everyone can handle it, even if they think they can.
Old Aug 14, 2003 | 11:13 PM
  #32
Teal94Z's Avatar
Automatics arent that hard to drive I know excuses will fly, but oh well, I know what happened, and the driver You make it sound like LS1's have 500 horsepower out of the box!
Old Aug 14, 2003 | 11:31 PM
  #33
HardcoreRM125's Avatar
Teal probly is great at driving a stick. Everyone on this board is mod crazy, alot of guys on here need to learn to drive lol ... I've seen a few guys on here that have stock M6 LT1 times of as good as even 13.6@102ish .... quite a few more in the 13.7 to 13.8 ... I personally dont think its so much that one is a factory freak and the others are average at 13.9's and 14/0's , but more the fact that only a few guys can really pound their LT1's to the limits and are great at driving sticks ... Theres no way a LT1 is making the power of an LS1, yet like 5 ppl on this board who are stock are running LS1 times, and in LS1 tech there are some guys pulling less then 13's stock, ... Its all because theyre great at shifting/launching ... Teal probly can throw 60' times like no other ... Race him before you guys call bs ... No mods are better then excellent driving
Old Aug 14, 2003 | 11:58 PM
  #34
will62085's Avatar
my freinds 2000 ss will bark 3rd, with 275 tires...my car wont bark third with 245's, but i can out run him by about 2 car lengths to 100 mph...and thats car, not driver, becuase in between shifts, my car pulls on his
BTW, those dyno numbers in my sig are before the ram air, and the exhaust (LT's, true dual with single chamber flows)
Old Aug 15, 2003 | 12:03 AM
  #35
Teal94Z's Avatar
Haha, already raced him a few months ago, and I won by a car, crept away the whole time
Old Aug 15, 2003 | 08:40 AM
  #36
stereomandan's Avatar
Sounds like the car is running good. Enjoy.
Unless there is something messed up with the shift points, causing the chirp.
Dan
Old Sep 16, 2003 | 02:10 AM
  #37
scoobysnax83's Avatar
Dan
There's only one way to mess up shift points in an M6
Old Sep 16, 2003 | 02:39 AM
  #38
rskrause's Avatar
Moderator
I am pretty tired about hearing of "factory freaks". More or less, this ain't gonna happen. Deviations from spec will almost certainly make a car slower, not faster. Kind of like spontaneous mutations in bio systems - they are very seldom advantageous.
Now, if you are talking about cars that aren't brand new, the condition will have a lot to do with how much hp they make. And even if you are talking new cars, remember that 4th gens came with a a variety of rear ends as well as some tranmission variants, slightly different cams from year to year, different cat setups, etc. The actual hp probably varied a bit more than the rated hp suggests. There are also weight differences between different cars based on the accessories. And of course, the driver weight will differ, also causing performance variations. And there is the batch-fire/speed density '93 vs. the sequential/MAF setup on the '94's and up.
A rational explanation of which stock variant is the quickest and fastest would be interesting. I don't enough of the nitty gritty details of the variations to know the answer myself. Probably the fastest will be some variant of the '95 or earlier 1LE due to the weight factor. But I mean besides these.
Rich Krause
Old Sep 16, 2003 | 02:50 AM
  #39
I love reviving old threads. See if I hadn't we would have missed out on the wisdom of rskrause
Here's a quick off the wall question. Why does my Throttle Body say MPFI on the bottom as if it is advertising Multi-Port Fuel Injection?
Old Sep 16, 2003 | 01:40 PM
  #40
rskrause's Avatar
Moderator
'Cause some mo-ron at GM thought it was cool?
Rich Krause
Old Sep 16, 2003 | 01:56 PM
  #41
Rich Krause
I'm glad I got the technical response
Old Sep 16, 2003 | 01:58 PM
  #42
Cmr0z28's Avatar
Re: Wow my mechanic just said my fuel pressure was in the teens (need advice)
Originally posted by speed76demon
just wondering before i order my new pump. can the pcm change the fuel pressure? my mechanic was like i couldn't believe its that low and still runs so strong. He also said thats prolly why it takes a few cranks to turn over so should i just order my new pump?
wtf did u just post it in this thread for?
Old Sep 16, 2003 | 02:03 PM
  #43
Re: Re: Wow my mechanic just said my fuel pressure was in the teens (need advice)
someone had a brain fart
Old Sep 16, 2003 | 05:27 PM
  #44
robb4964's Avatar
Re: I think i may have a factory FREAK
Originally posted by jasons93z
I have always thought my car FELT fast, but i was with a friend the other day and he wanted to me to get on it. We went from a stop and there was no traction in 1st, it chirped HARD going into second and then chirped pretty hard (at about 65mph) into 3rd . I was suprised to say the least.
Into third at 65 ? sounds like you got gears !!!! My car ran over 100 in third w/3:23's . Now its round 60-70 into third w/410's so it sounds common ...No traction in 1st ....another indication , although mine did that w/3:23's Im sure your car still runs strong
Old Sep 16, 2003 | 05:29 PM
  #45
robb4964's Avatar
If its an auto , you just push the gas ....I have seen auto LS1's run 14.3 at the track ..Although most of them have a ton of power like you said .....
