I keep hitting rev limiter in an auto
Old Jan 30, 2003 | 12:05 PM
  #31
'94 Bad A Z28's Avatar
Originally posted by z2894convertible
My car will hit it every time at WOT when going from 1-2 and half the time when going from 2-D. Is there a way I can or a transmission shop can check to see if it is slipping?
It is deffinately slipping... The 4L60E ALMOST never hits the revlimiter, unless it is on it's way down the crapper.
Old Jan 30, 2003 | 12:13 PM
  #32
Tibbys96Z's Avatar
Mine had the same symptoms when my torque converter went.
Old Jan 30, 2003 | 05:31 PM
  #33
SStupid's Avatar
Causes
The primary cause for converter failure is crap (metal, clutch material, broken stuff) that exits the failing tranny and enters the converter fins with a most haneous objective.
Old Mar 11, 2003 | 04:18 PM
  #34
Eddie Z-28's Avatar
My car hits the rev limiter from 1-2 and 2-3. It drives me insane, I need to make it stop. What about deleting the torque manegment? Help!!
Should I just smoke the trans I've got in my car untill it dies? Or should I try a shift kit? Cooler?
Old Mar 11, 2003 | 04:22 PM
  #35
twells's Avatar
my tranny did this for about a week. i changed the fluid and filter and haven't had any problems with it since. good luck
thomas
Old Mar 11, 2003 | 05:17 PM
  #36
RamAir95TA's Avatar
A friend of mine has the exact same problem.
He had the rev limiter raised to 6400, and voila. No more problem. Need proof?
http://www.fbody.com/cgi-bin/lt1/read.cgi?msgid=91637
Old Mar 11, 2003 | 07:32 PM
  #37
z2894convertible's Avatar
I raised my rev limiter to 6300 and that helped for a little while. Then I lowered my shift points and that helped for a little while. Now I am back to where I was. What would I have to replace on the trans to take care of this?
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
