I keep hitting rev limiter in an auto
Old Jan 14, 2003 | 11:06 PM
z2894convertible's Avatar
What would cause this? I don`t know why it keeps hitting my rev limiter. It is supposed to shift at 5700 rpms, but it doesn`t. I need to figure this out soon because I have nitrous kit that I want to have installed. It shuts my fuel off when I hit the rev limiter. I don`t want to hear my car go BOOM if that happens and I am spraying.
Old Jan 14, 2003 | 11:13 PM
Supermanx500's Avatar
It means that you are about to spend some major money on rebuilding your tranny.... I know....Mine did the same thing for a little while and then it just died one day.
Old Jan 14, 2003 | 11:17 PM
It isn`t slipping and it shifts hard. Could it still be the trans?
Old Jan 14, 2003 | 11:20 PM
Most likey....Trust me the trannys on ur cars are not all they are made out to be.....If you are spraying at all it will tear it up even more
96z's Avatar
96z
Have you modified the shift points at all?
Old Jan 14, 2003 | 11:22 PM
Might be your tranny silienoids
Old Jan 14, 2003 | 11:44 PM
My shift points haven`t been modified. I think I have a bad 02 sensor. Could that cause this?
Old Jan 14, 2003 | 11:52 PM
SStupid's Avatar
No
The first thing you want to do is check your fluid level. I don't know your knowledge level, so don't think I'm insulting you by suggesting this. Be sure and check it while the car is running and on a level surface. The next thing to do if your fluid is at the correct level is look at the color and smell it. Is it brown and does it have an acrid sort of burnt smell to it? If so, go pay the $139 to get the fluid sucked and the filter changed. You might consider a filter change, anyway. If all of this yeilds the same result, you are definitely having a clutch slippage issue. It will then be time for a rebuild or purchase of a "netgearheads" refurb. I'm sorry if it is the latter.
Old Jan 14, 2003 | 11:58 PM
'94 Bad A Z28's Avatar
My revlimiter "mysteriously dissapeared." Shifts when I shift it or when the computer tells it to if I don't manually shift.
Re: No
I have done all of this. It isn`t looking good for me:-(
Old Jan 14, 2003 | 11:59 PM
SStupid's Avatar
Sorry
Sorry, man. Time to shell it out. Gotta love the 4L60E.
Old Jan 15, 2003 | 12:05 AM
synethics's Avatar
Is it really hitting the rev limit or is it just hesitating at a lower point the the accuall rev limit. I had a hesitation problem at lower rpms that acted like it was hitting the rev limit and it just turned out to be my ignition coil and module...
Old Jan 15, 2003 | 12:06 AM
Wild1's Avatar
I've got a 700R4 on Ebay this week. http://cgi.ebay.com/ebaymotors/ws/e...item=2400263547
Old Jan 15, 2003 | 01:47 AM
96z's Avatar
96z
Dont know if youd be interested but I have a 4L60E that I just took out of my Z it shifts perfectly and hard and has a transgo shift kit already installed. It has 42K on and was used with a tranny cooler.
Old Jan 15, 2003 | 06:54 AM
my96z's Avatar
Try to raise the rev limiter and change the shift points. It may not be your tranny...
