I Hate My Car!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 28, 2004 | 01:23 PM
  #16
revtime's Avatar
If you want something you don,t have to work on buy a kia.
10 year/100k warranty.
I would rather have someone shoot me in the head but hey it sounds like thats what you need.
High performace cars require regular maintence. If you drive them hard they are going to break so you need to be comfortable with fixing them.
Its the nature of the beast......live with it.
Old Feb 28, 2004 | 04:38 PM
  #17
scoobysnax83's Avatar
BTW: The reason that me and everyone else is coming off as A-holes is because we are trying to motivate you to fix it. I understand that money is hard to come by. I'm an underpaid military man myself. But, I make it happen because I love my car with a passion. Don't give up yet....
Old Feb 28, 2004 | 05:18 PM
  #18
Kataklysm's Avatar
A fuel line disconnect tool is 5 dollars.
Old Feb 28, 2004 | 05:43 PM
  #19
EviLZ28's Avatar
Owning an F-body takes alot of patience at times. All cars need maintanence or do you just want to gas and go????
Old Feb 28, 2004 | 06:38 PM
  #20
TArider21's Avatar
Unhappy Another failed mission with my car
Well, I got the fuel injectors in, didn't have to remove the fuel lines. But, the injectors I got are Bosch 28 lbs/hr, the ones used in the LS1, and the clips used to retain the fuel injectors in the fuel rail will not work on the new injectors. Got all the new injectors in, without using any clips, and the #2 injector popped right out of the rail, so I had to remove them, and put the originals back in. Does anybody know where i can get some clips from an LS1 , so I can use these injectors in my car, because I noticed the car fired right up with these injectors, and I believe that my old injectors are leaky. The injectors might be the only problem, so I might not have to have the fuel pump installed!
Old Feb 28, 2004 | 09:17 PM
  #21
see you're on your way. Some people do not even use the clips in some cases and they have not run into a problem. But, if you need clips, just get in contact with Jason Chromer or Dal and they can get some to you overnight if you need them. And they are hella cheap!
BTW: Jason Chromer 1-850-243-8826
Old Feb 29, 2004 | 06:54 AM
  #22
TArider21's Avatar
Talking
Thanx Scoob!
LastChance719
Dec 3, 2014 07:55 PM
USAirman93
Nov 24, 2014 03:37 PM
regular Joe
Aug 10, 2002 07:15 PM
regular Joe
Aug 8, 2002 03:47 PM
regular Joe
Aug 8, 2002 07:53 AM
