Hypertech fuel pressure gauge
Old Jun 8, 2005 | 07:53 AM
Feenix's Avatar
I am looking to pick one of these up but upon checking out the jegs website, I see this in the description...
This hand-held gauge must be used with the adjustable fuel pressure regulator to indicate final fuel pressure. .
Is this true?? Im not going to get a AFPR just so I can use a test gauge. If thats the case I'll just look elsewhere. It just seems tough to find one with a long enough hose to do a WOT test.
Old Jun 8, 2005 | 08:28 AM
Re: Hypertech fuel pressure gauge
They are not saying you have to have an AFPR before you can install the gauge. They are saying IF you have an AFPR, you need the gauge to adjust it.
It will work fine with the stock FPR, since it screws onto the Schrader valve, and doesn't interface with the FPR.
Old Jun 8, 2005 | 08:34 AM
Feenix's Avatar
gotcha, thanks Fred.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Moshbmx1
Feb 17, 2015 10:51 AM
thenewkid
Nov 27, 2014 09:41 AM
