fixed vacum leak,,now poor idle ??
Old Jun 6, 2005 | 09:40 AM
Mystic97Z's Avatar
got a 97 z28, forged 357 heads/cam etc.
air conditioning, air pump, and egr systems are all deleted.
because of my emissions here, i had to hook my egr selenoid back up, no egr valve though.
had a small metal pipe coming out of the drivers side of the intake manifold that had no hose on it, my dad said it was causing a vacum leak, so i plugged it up.
symptoms before i fixed: nothing, ran fine, when i came to a stop it 100% maintained a 1000-1100 rpm idle.
symptoms after fixed: when i am driving, and i come to a stop, the idle drops to around 4-500 rpms, and almost dies. oil pressure drops real low. does that for about 4-5 seconds, then picks back up to 1100 rpms and all is fine.
this also started happening RIGHT AFTER i hooked my egr selenoid back up.
is this a vacum problem? and if it is i might just undo what i did, because sometimes i gotta give it a lil gas when the idle drops...also, if i'd turn my wheel when it does this, it'd probably die cuz of the power steering.
thanks
-Jason
Old Jun 6, 2005 | 01:22 PM
Fastbird93's Avatar
Re: fixed vacum leak,,now poor idle ??
Sounds like you probably need to reset your IAC after correcting that vacuum leak.
Old Jun 7, 2005 | 06:13 AM
Mystic97Z's Avatar
so i need to flash my computer? or reset it? i have a scaner, maybe i'll try that today..
Old Jun 8, 2005 | 08:05 AM
Mystic97Z's Avatar
update:
cleared my pcm and it seems to fix the problem..when i come to a stop, it will still idle lower for a lil bit than it did w/ the vacumm leak, but alot better than it did before i cleared it the codes.
Old Jun 8, 2005 | 09:21 AM
turbo_Z's Avatar
Cracking the TB blades just a bit will help.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Alex Barnes
Jan 24, 2015 10:21 PM
MislMan
Jul 19, 2002 11:41 AM
