HV Oil Pump Issues.
Old Jul 14, 2006 | 06:20 PM
1racerdude's Avatar
HV Oil Pump Issues.
http://www.camaross.com/forums/showt...=460364&page=3
I have posted some info about HV pumps.
This is about all the wining about the issues of said pump and what it does and doesn't do.
Scroll down to the Loooong posts at the bottom of page three and page four.
Old Jul 14, 2006 | 06:49 PM
Josh'95Z28conv's Avatar
Re: HV Oil Pump Issues.
Maybe we can finally put to death the "HV pumps suck the sump dry" theory. Then again some people will still think that...
Old Jul 14, 2006 | 06:58 PM
1racerdude's Avatar
Yea.
Most of what is posted is hearsay or incorrect about this issue.
Old Jul 14, 2006 | 10:16 PM
rskrause's Avatar
Moderator
Except it's not a theory. It would be a fact.
Rich
Old Jul 15, 2006 | 10:41 AM
96capricemgr's Avatar
You swear HV is such a good thing yet I don't remeber you siting any examples of the stock system being insufficient.
I am aware of more oiling failures on HV equipped LT1s than I am with stock oiling LT1s.
For the pumping the pan dry thing I seems to me the one thing they had in common was sustained high rpm cornering which hindered normal drainback where same day same track stock oiling cars had no issue and obviously stock oiling cars make up the majority and many of us beat on them pretty hard.
Old Jul 15, 2006 | 11:16 AM
Rich
Where's your proof?
Old Jul 15, 2006 | 11:48 AM
rskrause's Avatar
Moderator
Where's your proof?
In a very large pile of very expensive parts.
Rich
Old Jul 15, 2006 | 11:56 AM
Rich
Old Jul 15, 2006 | 12:48 PM
Rich
Why should we trust that over the quote from Melling's MARKETTING department ?
Old Jul 15, 2006 | 03:10 PM
The Melling article is actually a bit weak in the "logic" department. Their main driving force for increased oil flow it the fact the a stock pump is designed to support only 4,500rpm, and when the RPM goes up in a performance engine, the oil demand goes up - suggesting that for some reason, the stock pump can't meet that demand.
But by their own admission, as RPM goes up, the pump flow goes up. Ergo.... if the stock pump can meet the demands of the engine at elevated RPM, why do you need a HV pump? My stock pump easilly supports the demands of my engine at 7,400rpm.
They kind of trip over themselves in the whole writeup
Old Jul 15, 2006 | 04:21 PM
LilJayV10's Avatar
I didn't read the article, but if you are talking about how HV pumps will suck a stock pan dry, it will, trust me. It happened the the engine i built, under WOT the oil presure would drop to zero, thats not good at 6grand. I pulled the pan and put a stock pump on it, the pressure is the same as the HV, but it never drops. Thats all the proof I need. cause I didn't believe it either. I do now.
Old Jul 15, 2006 | 04:27 PM
rskrause's Avatar
Moderator
You know what? I would have been skeptical too until I saw it. Why some people here choose to believe theory over hard data, obtained quite expensively, totally escapes me.
Rich
Old Jul 16, 2006 | 07:15 AM
marshall93z's Avatar
This might get good!
Old Jul 16, 2006 | 08:06 AM
The Engineer's Avatar
For what it's worth, Chad Golen recommends a HV oil pump with his LT engines.
http://www.cardomain.com/ride/2189634
Old Jul 16, 2006 | 08:38 AM
rskrause's Avatar
Moderator
The issue isn't HV oil pumps, it's HV oil pumps with a stock 4th gen pan.
Rich
