Hv Oil Pump
Old Apr 16, 2005 | 08:33 AM
Heatmaker's Avatar
Advanced Member
Hv Oil Pump
What HV oil pump is best....????
And if so Melling... what parts will I need to make it work? Gear drive? Springs? ETC.... summit is of little help.
Old Apr 16, 2005 | 08:39 AM
sleepy_z28's Avatar
Re: Hv Oil Pump
I run the Melling HV pump. It came with the necessary springs. You will need to buy the corresponding oil pickup tube for whatever pan you have and I recomend that you buy an ARP oil pump drive shaft or equivelant. I also replaced my oil pump drive assembly with a new one. The only reason I run the HV is because I want the volume there and since I run a 7 quart oil pan there's no chance of sucking the pan dry. I wouldn't do it with a stock pan.
Old Apr 16, 2005 | 01:46 PM
rskrause's Avatar
Moderator
Re: Hv Oil Pump
You should not use an HV pump with a stock pan. You can suck the pan dry, and then it's "ruh roh".
Rich
Old Apr 16, 2005 | 03:12 PM
crazypurgatory's Avatar
Lightbulb Re: Hv Oil Pump
Humm I have all ways run HV oil pumps in my carburated 350's.
Stock oil pans too.
Chris.
Old Apr 16, 2005 | 04:29 PM
rskrause's Avatar
Moderator
Re: Hv Oil Pump
I didn't say it was a certainty. Usually happens with prologed high rpm use. But it does happen. I learned this the hard way. Also costs hp with no gain. It's only needed if you have a "loose" setup with big bearing clearances.
Rich
Old Apr 16, 2005 | 04:57 PM
Re: Hv Oil Pump
I know what you mean Rich.
Prologed high rpm could do it.
I have not had a problem.
Knock on wood.
But it is possible.
Chris.
Old Apr 16, 2005 | 06:56 PM
Heatmaker's Avatar
Advanced Member
Re: Hv Oil Pump
I'm purchasing a Mildeon or however you spell it pan.
Thanks for the cool info.
Old Apr 16, 2005 | 07:07 PM
93black-ta's Avatar
Re: Hv Oil Pump
milodon pn 31902
Old Apr 16, 2005 | 11:22 PM
Heatmaker's Avatar
Advanced Member
Re: Hv Oil Pump
when you say "oil pump drive assembly" do you mean new gear drive?
Old Apr 17, 2005 | 01:05 AM
hvyss's Avatar
Re: Hv Oil Pump
Interesting. I have noticed that on a WOT run on my 40 overbore with a H/V Melling pump and stock pan the oil pressure drops about 10 lbs from 55 to 40-45 and slowly will recover. Hense sucking the oil pan dry. Correct?
HVY SS
Old Apr 17, 2005 | 01:48 AM
SVThuh's Avatar
Re: Hv Oil Pump
I will never run a HV pump.. If I were you, I would run the stock pump with the "White" spring.. It will give you an increase in pressure, but will not increase volume considerably.. You want a slightly high pressure pump, but not high volume..
Just my $.02
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
