How rich do these things come from the factor?
Old May 9, 2004 | 09:27 PM
sabre81's Avatar
How rich do these things come from the factory?
How rich do these engines run from the factory? Assuming a problem free engine with all sensors working correctly and the mods listed in my sig, what could i do with tunercat to get a few extra hp? generally i know the process involves making a run with datamaster or equivilent software and tuning spark advance accordingly, but is there anything else? Also just wondering what you guys have had luck with tuning wise.
thanks
Old May 9, 2004 | 10:52 PM
Red96Lt1's Avatar
I got just over 20 at the wheels with madz28. Before the tune I was running about 12:1 or so.
Old May 9, 2004 | 11:59 PM
CamaroSS30thAnn's Avatar
damn i wanna tune....but im waiting fro my headers
Old May 10, 2004 | 12:31 AM
At WOT, the PCM enters "power enrichment" mode, and calculates the "target" A/F ratio from a couple of variable.... but it generally comes out to 11.7:1. For peak power/torque, you generally want something in the 12.8-13.2:1 range. You can typically pick up 15HP by leaning the stock PE mode values out.
Old May 22, 2004 | 07:39 PM
sabre81's Avatar
Ok im looking at these tables, %change to fuel/air ratio vs rpm at wot and %change to fuel/air ratio vs coolant temp. First question is, why do the values vary at diff RPM? Why dont i just put -.8 in for every value in the %change to fuel/air ratio vs rpm at wot table? This gives me a 12.8:1 a/f ratio.
DirtyDaveW
Dec 1, 2016 05:37 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grabbem88
Mar 18, 2015 01:25 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Hal Fisher
Sep 14, 2002 09:36 PM
