How to plug holes after !EGR
Old Aug 26, 2003 | 02:02 PM
NVetro's Avatar
Hey all, i removed my EGR and AIR this weekend. I would like to know what you all used to block off that little metal pipe that comes out right above the PCV valve on the driver side. Anything else I have to plug that i forgot, besides that and the 3 ports (2 on back of intake and one on exhaust manifold).
Old Aug 26, 2003 | 03:58 PM
Re: How to plug holes after !EGR
You can get the 3 blockoff plates fro the EGR from SJM Manufacturing.
The AIR connections to the manifold take 22mm (single cat) or 18mm (dual-cat) oil drain plugs. Cap the AIR supply connection on the intake ducting with a 5/8" vacuum cap.
Not sure what you disconnected as far as " that little metal pipe that comes out right above the PCV valve on the driver side.". Did you disconnect something from the manifold? Are you talking about the vacuum connection for the EGR solenoid? If so, just cap it.
Old Aug 26, 2003 | 04:40 PM
NVetro's Avatar
OK thats exactly what i mean. The EGR selenoid connection on the driver side of the intake, right above the pcv valve. It has a black tube connecting to it, to a box, and then to the selenoid ont he back of the intake. What can i use to block off that little metal pipe that comes out of the intake for that. Everything else is blocked off, I got those 3 block off plates from SJM Manufacturing
Any ideas?
Old Aug 26, 2003 | 04:46 PM
You get the right size "vacuum cap"..... like a little black rubber condom, and you put it over the metal tube attached to the intake manifold. Don't worry about the end of the hose you removed.
Old Aug 26, 2003 | 04:51 PM
NVetro's Avatar
I cant find a small enough rubber thinger. I mean this pipe is smaller then a pencil. Where can i get one? Have any part numbers? Thanks bro.
Old Aug 26, 2003 | 06:09 PM
carlos64030's Avatar
Just take that fitting for the EGR hose to a hardware store, and match it up to a solid brass plumbing fitting of the same size to plug that hole in the side of the intake.
Old Aug 26, 2003 | 08:30 PM
NVetro's Avatar
Anyone have a size or any info on the fitting they used?
Old Aug 27, 2003 | 12:42 AM
steve10's Avatar
You have mail.
Steve
Victor Lamb
Aug 26, 2017 02:52 PM
timmy39120
May 8, 2015 11:41 AM
eanhl2004
Apr 4, 2015 12:01 PM
edman
Mar 13, 2015 09:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
