How much for cam install?
Old May 10, 2004 | 12:59 PM
z28marine's Avatar
What am i looking at to have the hotcam kit installed (RR, valve springs, lifters, etc)?
Old May 10, 2004 | 01:04 PM
turbo_Z's Avatar
If you have a shop do it then my guess would be in the $800-$1000 range. Now if you can find somebody local on this board with experience to help you out then probably considerably less... FWIW I helped a guy install his hotcam kit for $250 and some lunch/dinner.
Old May 10, 2004 | 01:46 PM
neil350's Avatar
Most shops around here charge $475-550 for cam and springs on an LT1. Which isnt bad seeing how much work it is.
Old May 10, 2004 | 01:49 PM
ibanez6rg's Avatar
I bought Jared Goldstar, but he came up for other "reasons"...
Old May 10, 2004 | 02:14 PM
CeeBee94Z's Avatar
If you have any sort of mechanical ability just do it yourself. I just recently did my cam swap myself. I had never done anything remotely close to this big before and it actually went real well. No problems with mine at all until I went to the track for the first time with the setup and collapsed one of my stock lifters....
It is very time consuming and you have toi take your time, but I would say do it if you have the ability cause it will save you a lot of money
Old May 10, 2004 | 03:15 PM
SLeePer350's Avatar
CeeBee how bad was your damage? I am concerned about reusing my lifters on an upcoming [second] cam swap...
Let me know, thanks!
Old May 10, 2004 | 03:20 PM
CeeBee94Z's Avatar
Well lets see, I revved to probably around 6400-6500 cause I didn't see my shift light turn on earlier so that was the first mistake. Basically what I think happened was that one or more of my lifters collapsed on the passenger side and then in turn cause one of the pushrods to actually snap in half. So it caused a good amount of damage. So now I have Comp R lifters on the way along with new pushrods. My advice to you is either buy the Comp R lifters OR when you get tuned don't have your redline set about 6200 or 6300 at most. (mine was programmed to 6500)
Hope that helps
Old May 10, 2004 | 05:59 PM
SLeePer350's Avatar
Do you see any advantage to Comp R's over 'new' stock lifters if the shift point was no more than 6300?
How much is the full set of Comp R's? Part #?
thanks a lot
Old May 10, 2004 | 09:00 PM
CeeBee94Z's Avatar
There is like a 10 dollar price difference between a new set of stock lifters and the comp R's so I see no reason to not get the Comp R's ever unless they are on backorder or something and you are in a rush. The part number is 875-16 I believe. Combination Motorsports has them for like 208 or so.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
