How many bolts?
Old Aug 10, 2003 | 04:17 AM
Compstall's Avatar
How many bolts?
I'm pulling my transmission so I can change the clutch. Just wondering how many bolts hold the trans to the bellhousing. I've gotten 8 bolts out so far. HOPEFULLY that's all of them?
Old Aug 10, 2003 | 04:25 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
well... does it come off?
i had the a4 so i couldn't tell ya...
but if it comes off... i say its a 95% chance ya got all of em
Old Aug 10, 2003 | 06:05 AM
Compstall's Avatar
Haven't tried yet, but I did think that myself. Since I'm doing this job solo, I'm kinda afraid of the weight of it. It's not TOO heavy is it? I don't have a tranny jack...
Old Aug 10, 2003 | 06:10 AM
frmula1's Avatar
the tranmission?!?
or the bellhousing?
the bellhousing shouldn't weight more than 15lbs...
my transmission with a t/c and fluid in it was a solid 175+ lbs
just use a floor jack under the pan....
Old Aug 10, 2003 | 06:52 AM
Compstall's Avatar
It's a manual tranny, ain't got no "pan".
I'm thinkin' I better go find me a tranny jack. Might make things a LOT easier when re-installing....
Old Aug 10, 2003 | 06:59 AM
frmula1's Avatar
oh yeah... lol manual trannys don't have fluid do they? haha...
i can't believe theres no place to put a floor jack on it tho...
its it at leadt somewhat flat? could just put a piece of wood between the jack and the tranny
Old Aug 10, 2003 | 03:15 PM
Compstall's Avatar
There really isn't any flat spots on the bottom. It's V-shaped at the bottom.
Yes, it has fluid in it, about 3-4 quarts in there I drained out.
Old Aug 10, 2003 | 04:57 PM
2hipbiker's Avatar
Post
I did took my tranny out by myself... had a tranny jack but the seal blew and that was a royal pita.. anywho i got some boards longer than the width of the car and propped the tranny on those and put cinder blocks on either side to hold it up and had another jack under the front of the tranny.. then later you should be able to finagle it back in... but its gonna be hard... or the easy solution... go rent a tranny jack
Old Aug 10, 2003 | 11:17 PM
T56 weighs 125# with fluid. You got all the bolts, if you counted 8. Don't forget to pull the clutch fork off the T/O bearing, or you'll never get the tranny out.... .
Old Aug 10, 2003 | 11:41 PM
Z95m6's Avatar
also don't forget the inspection plate the bellhousing won't come off with that on there. Ask me how i know
Old Aug 11, 2003 | 12:53 AM
Compstall's Avatar
I got it out myself today. Let the jack down a bit to get some slack between the tranny and bellhousing so I could wiggle it around a bit and get a feel for the weight of it. Wasn't too bad so I yanked it off and rolled it off my chest onto the floor.
Not sure if I can get it back in myself, but possibly if I can make it on the first stab or so.
I don't think I have a leak from the tranny input shaft, it's the rear main. How does that come out? The clutch/flywheel has done a good job of flinging off the oil, so that's why it hasn't failed, but I'd like to get that changed before I put everything back together.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
