How to hook up alternator wires for custom application
Old May 4, 2004 | 02:01 AM
LT1RX7's Avatar
I decided to dump the one wire alternator and hook up my stock LT1 alt. Can someone assist me in wiring this up? There is a plug with 4-5 wires coming from it. I don't really need all of them hooked up, just enough to make the car run and charge battery. And there is also a stud on the back of the alt. I'm assuming that goes to the +12 battery
Old May 4, 2004 | 06:16 AM
Mtrhds94Z's Avatar
My 94 LT1 has the CS144 140 amp alternator and it uses only one wire in the 4 pin plug..
The plug has pins for 'P',' L',' I', and ' S', but only 'L' is used [I believe it goes to the instrument cluster for the voltmeter gage]
Also, the large stud is 12V +[output] to battery..
The mounts provide the 12V - ground..
Old May 4, 2004 | 07:00 AM
SLeePer350's Avatar
what is the stock amperage just out of curiosity?
Old May 4, 2004 | 09:28 AM
I believe that was answered in the post above. (1993s were 124 amp)
The one small wire must have a 470 ohm resistor on it if you don't route it to the dash light or volt gauge. Normally, the light or gauge has that resistance built in.
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
CARiD
Jan 27, 2015 06:27 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
