How high can an LT1 spin safely>>
Old Jul 22, 2005 | 09:09 PM
mattbailey's Avatar
I'm getting ready to swap cams again. I'm going to a comp 230/236. I know I'll have to spinn the motor higher, but how high can I turn her safely? Last year, I pulled the motor, replaced oil pump, replaced head gaskets, timing chain, opti, water pump. The cylinder walls looked great (117,000 miles and still had cross hatch marks) Also replaced the cam bearings. I think the motor is pretty sound, what do you guys think?? Can I turn 6500 and be okay?
Old Jul 22, 2005 | 10:24 PM
Bow94z's Avatar
Re: How high can an LT1 spin safely>>
it can be done, the main thing that goes with high mileage cars with cams is spun bearings. just dont expect the bottom end to last long rev out to 6500
Old Jul 22, 2005 | 10:42 PM
MTL_Z28's Avatar
I think 6500 is a safe limit. I have the 230/236 and 6500 is where I have my limiter set at, and my bottom end is stock and untouched. You should be ok as long as you don't rev it there all day long.
Old Jul 23, 2005 | 12:13 AM
94 TA TT2S's Avatar
I say try it Matt.....We can always get you another motor....hehe...
What are you gonna do about the first gear in the tranny????
Old Jul 23, 2005 | 03:51 AM
Kain's Avatar
I've been running mine out to 6500 for two years, and everything's fine for me.
Old Jul 23, 2005 | 05:18 AM
redcamaroz28's Avatar
I have the 230/236 as well and shift at 6300 (well, should as soon as I fix my 5800rpm miss -bad opti or coil?) Before my miss started I was reving it to 6300, unfortunatly I haven't gotten a good dyno pull to see exactly where this cam peaks out, but from what I've read it's around 6200-6300.
Ryan
Old Jul 23, 2005 | 07:39 PM
mattbailey's Avatar
Hey Ben, I might have to take you up on that. I just bought some pistons off a guy on here, and have that old block sitting on my engine stand, but hopefully I won't have to use it before I get everything together. Some people told me that I would have to spin the motor ot 6500 just to max out the cam. I think she'll take it, but for how long is what I'm worried about.
Oh and about getting a lower 1st gear, I think I'll hold off and see how this cam effects my 60's. If it doesn't get any better, this winter Craighead will take care of it.
HectorM52
Jun 23, 2016 08:42 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
smacz28
Aug 6, 2002 01:51 PM
