how easy do opti's break
Old Nov 29, 2004 | 08:07 PM
Eff's Avatar
Eff
I bought my camaro back in April. Replaced the Opti, distributer seal, and water pump seal, water pump gaskets, opti harness, plugs, wires and o2 sensors. nearly the entire ignition. This fixed my problems for a while.
about 2 weeks ago they started again, Hi-Res and Lo-Res codes, Half the time it just cranks, and when it does start it won't advance and dies a lot.
Why is this happening. I really don't want to buy another opti, If it needs to be replaced, then what about that coil pack conversion. whats it cost?
Old Nov 30, 2004 | 01:33 AM
Eff's Avatar
Eff
Re: how easy do opti's break
is everybody just sick of answering opti questions, or does nobody have an answer.
Old Nov 30, 2004 | 03:10 AM
TobyZ28's Avatar
Could it be the little pigtail to the opti is old and not connecting properly?
Old Nov 30, 2004 | 03:15 PM
You've got two cars in your signature.... which one are you talking about? Is the Opti vented (possible use on 383 LT4) or non-vented (stock)?
Basically, need more details to answer the question.... might explain why you aren't getting any answers.
Old Nov 30, 2004 | 04:58 PM
mzgp5x's Avatar
Most of my breakage has been the rotor. The opti part has always worked. I have broken two. Looks like the copper contact comes loose with high energy CD ignitions.
Old Nov 30, 2004 | 05:01 PM
Loadre's Avatar
My stock opti did great for about 20k miles on a Mallory 685 box. Went ahead and swapped for a new one when the new motor went in, though.
Old Nov 30, 2004 | 05:52 PM
Eff's Avatar
Eff
I was refering to the stock 94 camaro, with an unvented opti.
KYWes
Jun 14, 2022 06:52 AM
Victor Lamb
Aug 26, 2017 02:52 PM
asilomar244
Jul 12, 2015 05:53 AM
