How do u take off the trans dip stick?
Old Jul 18, 2005 | 09:09 PM
JJJ93z's Avatar
taking off egr/A.I.R. , need to make more room
im in the process of installing Lts and im tryin to pull my emissions off the back of my intake and its EXTREMELY difficult with large hands, how do i take off the trans dip stick so i can get back there. i wont have to put new fluid in will i? also will pulling that valve cover make it easier thanks
Old Jul 19, 2005 | 12:11 AM
Re: taking off egr/A.I.R. , need to make more room
There is a tab on the tube that a transmission to block bolt goes through. With that removed the tube should pull out of the transmission (similar to the oil dipstick tube on the engine block). The fluid level should be below the tube.
Dealing with getting that out might be harder than what you are doing now. If you are careful, you can gently bend the tube up at the top to move it out of the way of some things. It won't go too far, but maybe enough for what you are doing.
Old Jul 19, 2005 | 12:28 AM
JKDZ28's Avatar
Hmmm...with my Mid-Lengths the Trans Dipstick didn't get in the way.
Could be another story with LT's though.
FredM
May 28, 2015 04:28 PM
warmeck
Mar 16, 2015 07:02 AM
Scottylt1
Jan 8, 2015 02:48 PM
Cam's maro
Dec 29, 2014 08:44 AM
Scottylt1
Dec 4, 2014 12:31 PM
