How do i get my BSFC
Re: How do i get my BSFC
Originally Posted by 97formula1234
it doesn't show mer duty cycle, it shows pulse with and in order to calculate duty cycle i need to know the BSFC
There are recommended figures to calculate the injector size. A N/A engine is usually rated at .5,but .45 is relevant too if it's efficient.Just use .5 and ya will have a small amount of growing room for more HP.
it doesnt show mr duty cycle, it shows pulse with and inorder to calculate duty cycle i need to know the BSFC
Time for two crank revs in milliseconds = (2/RPM) X 60,000
At 6,000rpm, time available is 20mSec. An 18mSec pulse width would give you:
18 / 20 = 0.90 = 90% duty cycle.
You do need BSFC to calculate required injector flow in #/HR. As indicated in the post above, you get that number with the engine on an engine dyno, measuring both flywheel HP and mass fuel consumption, see typical dyno output sheet, with BSFC in 5th column from right. That's for my engine with a 250 shot of nitrous, so the BSFC peaks at 0.53 #/HR/HP. Running NA, its about 0.44
http://members.aol.com/Fredrick518/dynoN2O.jpg
Dave88LX
Apr 21, 2004 08:30 AM
