survey - SC max hp on racetronix fuel pump
Old Nov 17, 2006 | 06:06 PM
jgeorger's Avatar
I'd like to take a survey of how much hp people have dynoed with a Racetronix single in tank kit - with the wiring and all. I'm most interested in supercharged guys who are not running FMU's - so as to keep the fuel pressure down and fuel flow up. If not quoting dynojet numbers please specify type of dyno.
When I was fuel pump shopping I used the following formula:
(HP)*(BSFC)*(1+safety margin) = lb/hr
Walbro 340 @ 13.5v:
50 psi: 246 lph
60 psi: 231 lph
Doing a little algebra and converting from lb/hr to lph:
HP = lph / (BSFC*safety margin*0.522)
So if I use a BSFC of 0.6 and a safety margin of 1.2 (20%) and assuming 245 lph if I run approx 7 psi boost:
HP = 245/0.37584 = 652 hp
I would be happy with this number.
Thanks,
Joe
Old Nov 17, 2006 | 07:02 PM
cjmatt's Avatar
i made 520 rwhp on a mustang with one, the guy said i may be running out of fuel though
Old Nov 17, 2006 | 07:09 PM
joe-96z1le's Avatar
I've heard the Racetronix should be good to that level but you could always add a BAP. Kenne-Bell or MSD. That should be good up to 700+HP.
Old Nov 17, 2006 | 07:45 PM
94 NO TOP Z's Avatar
I have the racetronix kit (255 pump and racetronix wiring harness) and it will safely do 14psi on my 355 (approx 550RWHp). Since I've added the Kenne Belle BAP I have done 20 psi and a little more with no problem. Stock fuel lines, 72 lb injectors.
Old Nov 17, 2006 | 09:17 PM
jgeorger's Avatar
And if I drop the 20% safety margin then I get 782 hp. So the question really is - what is the fuel flow rate up at the fuel rail? I'd obviously be happy if it was less than 20%.... Thanks for the answers so far guys. Guess I'll find out for sure when I strap this puppy on. I don't know what kind of boost it will make with my combo and the standard pulleys, so I don't know what hp I'll end up with.
Joe
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
