How do i get my BSFC
Old Aug 14, 2005 | 04:44 PM
93transam1234's Avatar
I dont have a dyno but my mods in my sig.
Trying to find out if i have enuf injector for my setup
(stock Inj.)
Old Aug 14, 2005 | 04:50 PM
Jameslt1TA's Avatar
Re: How do i get my BSFC
You probably do. But the best way is to get datamaster and run a wot log on your car. See what the % duty cycle is. I think that anything over 90% is pushing it.
Old Aug 14, 2005 | 05:37 PM
i got auto tap, i am just trying to understand how the calculation is done
Old Aug 14, 2005 | 05:54 PM
Jameslt1TA's Avatar
It should tell you the injector duty cycle. Im not to sure about auto tap though. I would say that you have enough injector for you setup but it would be nice to know.
Old Aug 14, 2005 | 06:00 PM
it doesnt show mr duty cycle, it shows pulse with and inorder to calculate duty cycle i need to know the BSFC
Old Aug 14, 2005 | 09:05 PM
1racerdude's Avatar
Originally Posted by 97formula1234
it doesn't show mer duty cycle, it shows pulse with and in order to calculate duty cycle i need to know the BSFC
BSFC will only be learned on an engine dyno.
There are recommended figures to calculate the injector size. A N/A engine is usually rated at .5,but .45 is relevant too if it's efficient.Just use .5 and ya will have a small amount of growing room for more HP.
Old Aug 14, 2005 | 10:48 PM
You don't need BSFC to calculate duty cycle. To calculate duty cycle you need the pulse width and the RPM from a frame of data. Divide the pulse width by the number of milliseconds it takes to complete 2 crank revolutions at the RPM in the frame. That's duty cycle.
Time for two crank revs in milliseconds = (2/RPM) X 60,000
At 6,000rpm, time available is 20mSec. An 18mSec pulse width would give you:
18 / 20 = 0.90 = 90% duty cycle.
You do need BSFC to calculate required injector flow in #/HR. As indicated in the post above, you get that number with the engine on an engine dyno, measuring both flywheel HP and mass fuel consumption, see typical dyno output sheet, with BSFC in 5th column from right. That's for my engine with a 250 shot of nitrous, so the BSFC peaks at 0.53 #/HR/HP. Running NA, its about 0.44
http://members.aol.com/Fredrick518/dynoN2O.jpg
Injuneer
Jan 19, 2010 02:02 PM
jgeorger
Nov 17, 2006 09:17 PM
Mustang4Lunch2
Apr 3, 2006 03:17 PM
Dave88LX
Apr 21, 2004 08:30 AM
Dave88LX
Apr 4, 2004 05:16 AM
