Sweet Injector sizing charts that I made up!
Old Apr 2, 2004 | 04:32 PM
Dave88LX's Avatar
Check out this chart, could be pretty helpful. As I was sitting here trying to figure out what size injectors to go with, I decided to go learn the math, and come up with some spreadsheets to illustrate the differences PSI, BSFC, and DC can make.
Keep in mind there are THREE DIFFERENT TABS at the BOTTOM of the page, There's 3 different charts in this file.
http://paradox.shacknet.nu/dave88lx/.../injectors.htm
For an example of how it can be used:
Starting at tab 3, looking at that chart, say I want to maintain 80% injector duty cycle (Which is what seems to be the standard reccomendation), and want to crank out 550 HP at the flywheel. Estimated BSFC to be is .45, (But you can choose whichever BSFC you think it will be); then I need 38.67 lbs of fuel per hour.
Going to tab 1, I can run an SVO 36# injector (Blue columns) at 46PSI and get 39 lbs of fuel/hour.
Or, I can get an injector that's got it's rating taken at the 43.5 PSI (In the Chevy column colored Red), and run that 36# injector at 51 PSI and get 39 lbs of fuel/hour that is needed.
The middle tab just illustrates at 75%, 80%, 85%, and 90% injector duty cycle, with different size injectors, and BSFC, how much HP the injector can support.
Seems it could turn pretty useful, no?
Let me know if you don't understand something.
Old Apr 2, 2004 | 04:48 PM
Siamanis's Avatar
whats the brake specific fuel consumption?
Old Apr 2, 2004 | 05:40 PM
jkipp84's Avatar
BSFC
Old Apr 2, 2004 | 05:46 PM
TobyZ28's Avatar
Nicely done
Old Apr 2, 2004 | 05:49 PM
Siamanis's Avatar
Thumbs up
you learn something new every day!
Old Apr 2, 2004 | 10:45 PM
Dave88LX's Avatar
Thank ya!
I believe I read not to go over 60 PSI, but I think it's Injuneer that's hitting like 73PSI under boost
Old Apr 2, 2004 | 11:42 PM
ishz28's Avatar
Very nice job!!
Old Apr 3, 2004 | 11:35 PM
Dave88LX's Avatar
I think it about makes sense...I may add a couple other things into it when I get time.
Old Apr 4, 2004 | 12:28 AM
Originally posted by Dave88LX
Thank ya!
No... I run Bosch 64#/HR injectors, at 58psi (4 bar) = ~78#/HR flow.
But... the NOS 5176 dry nitrous kit that I used to use ran the fuel pressure at 85-90psi when the system sprayed... and the pintle style injectors (Bosch, SVO, FMS, Accel) seemed to survive just fine.
Old Apr 4, 2004 | 05:16 AM
scoobysnax83's Avatar
Hey Fred, did you go to the EFA Fall Shootout last year. Your car looks really familiar.....
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
grgguy
17
Feb 23, 2015 07:57 PM
Joes96z
Dec 13, 2014 07:48 PM
