How difficult is it to replace the steering rack??
Old Jan 5, 2004 | 01:05 PM
CARGUY's Avatar
Question How difficult is it to replace the steering rack??
Did a search and didn't find much? My steering rack is going, I have ALOT of play in the wheel and while stopped going left to right quickly back and forth you can hear it clunking. So, I'm just curious if this is a pretty straight forward job or not. Also how much would this cost?
On a side note, are there any quicker ratio steering racks out there for an LT1 fbody? I like do autox every now and then and a quicker rack would be nice. Oh, I have a 97 Z28.
Thanks for any help!
Old Jan 5, 2004 | 02:58 PM
CARGUY's Avatar
Everyone is on their original steering rack?
Old Jan 5, 2004 | 03:01 PM
93redbird's Avatar
ttt.. I want to know also
Old Jan 5, 2004 | 04:40 PM
CARGUY's Avatar
geez, lets try it again I guess?
Old Jan 5, 2004 | 05:09 PM
ROADRAGE's Avatar
On an LT1 car, its very easy. Only thing holding it on are 2 bolts through the k member, the tie rods, and the 2 fluid lines. Takes under an hour. LS1 isnt so easy. one of the k member bolts wont clear the engine block.
No idea on the quicker rack though. would be nice if they had one.
Old Jan 5, 2004 | 05:27 PM
CARGUY's Avatar
Great, thanks for the reply! So this can be done with regular hand tools? Is there anything I should be aware of, oh and maybe a stupid question... do you need to get an alignment afterwards for possibly messing up the toe?
Old Jan 5, 2004 | 06:02 PM
naztyz28's Avatar
yes u will need alignment also when you bleed the system raise both wheels off the ground with the pass side being higher then the driver , bleedin sytem on the ground can cause premature failure
Old Jan 5, 2004 | 06:19 PM
v7guy's Avatar
as far as unbolting it, it's breeze, putting it in and pulling it were quite the task though as it's a tight squeeze, especially on the side with the rubber. nothing that's that difficult though
naztyzs8 pretty much covered it though
Old Jan 5, 2004 | 06:56 PM
CARGUY's Avatar
Cool thanks guys. If its not any harder than waterpump and opti then I'm ok.
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Airplanedoc
Feb 1, 2015 07:14 PM
Hurin
Dec 13, 2014 07:38 PM
