How can i pick up .2 ?
Old May 23, 2003 | 01:56 PM
  #121
LT1derful's Avatar
Originally posted by Zepher
I guess no one read my post on the supports.
They are for 2.5mph impacts to keep cosmetic damage down to a minimum.
I saw it...sorry, too busy helping Trey make himself look even more stupid in an effort to swim himself out of all his BS.
You are right. They are made for low impact collisions to save the front and rear skirt from damage other than cosmetic. However, I do feel that the front support could perhaps save your radiator at the same time. While they do absorb shock, I have serious doubts against their life-saving capabilities.
Old May 23, 2003 | 01:57 PM
  #122
Shon Herron's Avatar
Originally posted by treyZ28
my car has never been run, get over it. Its not going to be run for a while due to companies sending me incorrect parts.
Dang Vendors keeping you off the track.
So you dont really know what weight reduction/addition will do to your car.
Let us know when you get that 383 in the 12s, we will be looking at 11s by then.
Old May 23, 2003 | 02:06 PM
  #123
96 TA's Avatar
LT1derful didn't say that just removing the bumper supports will lower your et .4sec. He also said to try et streets/drag radials, pull the swaybar, remove the back seats, and so on.
I know from experiance that tires are good for .2sec. When your on street tires going to a drag radial helps wonders.
Removing the swaybar adds to better weight transfer which will help reduce your et.
Removing backseats, bumper supports, belt and so forth all adds up. And I belive there good for a couple tenths as well.
So there is your .4sec. He never said removing just bumper supports will cut your et. .4. But doing the above and learning how to drive your car better will.
Trey, honestly now you can't tell me that what I just stated isn't good for .4 tenths. Think about it and tell me that, tires, better weight transfer, weight reduction, and sharpening his driving skills didn't gain him what he said. he has no reason to lie.
Old May 23, 2003 | 02:16 PM
  #124
LT1derful's Avatar
Well, obviously since he's never ran his car, he wouldn't know. Funny, he's arguing with someone that DOES run their car. And...it's not printed in Super Chevy...must not be true.
Ran my car with and without the belt; .22 sec different 1/4 mile. It's about like having an electric water pump and doing the alternator relocation; except that you can't drive your car around like that, lol.
Old May 23, 2003 | 02:19 PM
  #125
Zepher's Avatar
Ya you can, just get a lot of extra batteries.
Old May 23, 2003 | 02:21 PM
  #126
LT1derful's Avatar
"Why's your car sit so low in the back?"
Old May 23, 2003 | 02:22 PM
  #127
KamaroL98's Avatar
nuff said....
No need to start talking **** trey.
Just becaus we are from SC dosent make us rednecks, there are rednecks in china. And just becaus your from michigan dosent mean your not white trash and everyone there has faster cars becaus everyone in the US gets the same performance parts, dosent matter which company they order from.. Why do you got to make insults?
People do whatever they can to knock of an extra tenth. It may call for hacking off a little safety or emmissions feature here and there and if your willing to take a risk or loss its all up to you... Its not like we are hacking off fenders, hoods, body parts, or ditching our car stereos. I dont even agree with removing some of the things lt1derful mentioned like the sway bar, but it does work to better E.Ts, especially in conjuction with other things he mentioned.
Old May 23, 2003 | 02:32 PM
  #128
96 TA's Avatar
Oh really! Thats cool, so next month when I get my electric water pump, new opti, and new coil/wire ill go to the track and do what weight reductions I can and pull the belt I should see my 8.7 drop a few tents. Ill only do that if my new clutch is in. If I saw my 8.7 turn into a 8.3 or better id ****! I run about 82.5mph now so if I do tho's things how much mph should I pick up? What was your 60ft on that 8.7? Mine was 2.08x so almost a 2.1. With my bad clutch, I could possibly see a 1.9 right now with a better clutch witch would net me somewhere in the 8.5's with no weight reductions. Sorry, im just starting to get wild up at that thought of running in the low 8's because for the longest time I thought my car was just slow.
Old May 23, 2003 | 02:35 PM
  #129
Zepher's Avatar
What? Like this?
http://www.transamws6.com/pics/trans..._pass_side.jpg
Old May 23, 2003 | 02:38 PM
  #130
LT1derful's Avatar
My 8.7 mph was right at 82 (a high 81.9). My clutch grabs like an ape! The 60' sadly was like a high 2.09 and low-mid 2.1s. With the 8.3-8.4 passes short times were 1.9x consistently with the best being the 1.92. Just couldn't get a 1.8 that day. You should be able to see times like mine, since you are running almost exactly what I was prior. What clutch you getting?
Trey loves when we chit-chat in the "tech forums"...
Old May 23, 2003 | 02:44 PM
  #131
LT1derful's Avatar
What? Like this?
Old May 23, 2003 | 02:50 PM
  #132
Zepher's Avatar
How does that 1/8th mile conversion work?
I ran a 9.582 @ 73.11mph with a 2.126 60' with the carb 305.
Then with the TPI on the 305, I ran a 9.297 @ 79.52mph with a 2.335 60'
What would my 1/4 mile times be?
Old May 23, 2003 | 02:53 PM
  #133
96 TA's Avatar
I have the LT4 clutch waiting to be installed, From what I understand it shares the same pp as your stage two spec but retains the stock LT1 disc. It should hold well against the mods I have.
Old May 23, 2003 | 02:55 PM
  #134
96 TA's Avatar
If I had to guess I would say somewhere around 14.3 - 14.5 in the 1/4. I don't know the actual convershion but thats my best guess.
Old May 23, 2003 | 02:59 PM
  #135
Typical Fbod with LT1 is 1/8th mile time divided by .63.
I run 7.8/.63=12.38, that is about right...
