Hot Cam spring pressure
I believe they are 105 lbs at the seat and 280 open. The Hot cam springs barely work for the Hot Cam and they are VERY close to coil bind. I would rather have more seat pressure but there is no room since coil bind is so close anyway.
I would recommend the Combination Motorsport (702-798-8504) 612 springs. they are $80 for spring, retainers and locks. They require no machining and will have about 130 on the seat and about 330 open. they can handle quite a bit more lift as well (.570 to .580 depending on set up ht.).
NightTrain66
NightTrain66
Speeds8erM-1
Jul 28, 2002 06:18 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
