Hot Cam kit...bigger injectors required?
Old Oct 28, 2009 | 06:50 PM
1993Fast_Z's Avatar
does the hot cam kit require bigger injectors(like 30 lbr.'s) or can you use stock 24 lb.?
Old Oct 28, 2009 | 08:26 PM
MikeGyver's Avatar
24's are fine
Old Oct 28, 2009 | 11:31 PM
SnakeOiler's Avatar
Just make sure you check your duty cycle. I have SVO 30lbs and the highest DC I have seen is right around 72%
I don't know where is will sit with the stock injectors, but if it's over 85% you should swap up to some bigger ones.
Old Oct 29, 2009 | 02:06 AM
MikeGyver's Avatar
A hotcam kit might add like 20hp or whatever. Theres no way GM would/could size factory injectors that max out barely over the engines rated HP.
Old Oct 29, 2009 | 09:21 AM
slomarao's Avatar
if you break 345-360rwhp than I would go 30lbs. At that point your approaching 75-85% duty cycle. Its hard to say. If you can find LS1 28lbs used I would for something like that.
Old Oct 29, 2009 | 05:18 PM
An LS1 28 #/HR injector (flow rated at 58psi) flows exactly the same as a 24 #/HR LT1 injector, when the LS1 injector is used in the LT1's 43.5psi fuel system.
He doesn't need upgraded injectors yet.
Old Oct 29, 2009 | 06:37 PM
henryz28's Avatar
I have the hot cam and you will be good with stock injectors. If you do some head work and a larger cam then you need to think about injectors. And if you decide to run NOS or Forced induction.
Old Oct 31, 2009 | 09:12 AM
RobsWS6's Avatar
As everybody is saying, the stockers are fine. I've had the HOT cam for over 12 years in my car, never had a problem with fueling.
Parent's have LT4 HOT cam, heads/intake on both T/A's and still run on the stock injector. The M6 car dynoed at 375rwhp over 10 years ago. Still on stock injectors.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
Smokn '94 Z
Jul 28, 2002 02:38 AM
