Hot Cam kit...bigger injectors required?
Just make sure you check your duty cycle. I have SVO 30lbs and the highest DC I have seen is right around 72%
I don't know where is will sit with the stock injectors, but if it's over 85% you should swap up to some bigger ones.
He doesn't need upgraded injectors yet.
As everybody is saying, the stockers are fine. I've had the HOT cam for over 12 years in my car, never had a problem with fueling.
Parent's have LT4 HOT cam, heads/intake on both T/A's and still run on the stock injector. The M6 car dynoed at 375rwhp over 10 years ago. Still on stock injectors.
Smokn '94 Z
Jul 28, 2002 02:38 AM
