hot cam compression test
Old Dec 12, 2005 | 07:07 PM
Sunsceamer's Avatar
I am wanting t look at a car with a hot cam kit with the rockers on it and was wanting to know what the psi area sould I look for while doing a compression test.
Old Dec 12, 2005 | 07:20 PM
1racerdude's Avatar
Re: hot cam compression test
Do a leak down test. It will tell ya more about the wear on the engine.
I think thats what ya are asking..
Old Dec 13, 2005 | 05:47 AM
Sunsceamer's Avatar
I know it will tell me more but the car is a hour and a half away. I was going to do a comp test just as a check just looking for a #.
Old Dec 13, 2005 | 09:05 AM
There is no one number that you can look for in a compression test. The objective is to see how closely the 8 cylinders match. You will get a huge variation in results, based on engine temperature, how wet the cylinders are, how strong the battery is, how many times you crank it, whether you remove all the plugs and block the throttle blades open, etc. I've seen people report anywhere from 150-195psi on a healthy LT1. The goal it to have the cylinders close to each other.
Magenta_Hearts
Mar 25, 2015 10:24 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
