Hooker LT install!
Old Feb 28, 2004 | 04:17 PM
cocheese's Avatar
Hooker LT install!
Hey guys, i'm finally in the process of installing my LT's, so i'll be back and forth on here w/questions i'm sure. First of all, i'm in the middle of removing the pass side exhaust manifold, do i need to remove the alternator to get it out?
Thanks,
Ryan
Old Feb 28, 2004 | 04:22 PM
ChevyIron's Avatar
Yes go ahead and take out the altnator It will give you more with the long tubes to.I know I also had to remove the steering knuckle on the drivers side.
Old Feb 28, 2004 | 05:15 PM
cocheese's Avatar
Thanks. What else will need to be removed? I'm guessing the starter will come out as well.
Old Feb 28, 2004 | 06:23 PM
cocheese's Avatar
Do i need to get different O2 sensors, mine are still good, but is there a special kind i need to get? I thought i heard someone say that, so i'm left wandering.
Old Feb 28, 2004 | 06:38 PM
Botch's Avatar
You should already have heated O2s in your car so your stock ones will work. You will either have to cut and splice your O2 sensor wires or get O2 extensions to get them hooked up in their new location.
BUY BAND-AIDS!! Everything is sharp under these cars.
Other than that you should do ok.
Old Feb 28, 2004 | 08:04 PM
Brent94Z's Avatar
Super Moderator
Remove the alternator and starter... makes things much easier
Old Feb 29, 2004 | 12:02 AM
carlos64030's Avatar
Be prepared to jack the motor up...you may, or you may not have to.
Old Feb 29, 2004 | 08:40 AM
Brent94Z's Avatar
Super Moderator
Yes, this is strange. On my 94Z the Hooker long tubes went right in. Yesterday we installed Hooker long tubes on the 96SS and had to jack up the engine
Strange, eh?
Old Feb 29, 2004 | 12:31 PM
Black94mula's Avatar
Okay I have a question about the O2's too as I'm gonna be installing mine soon. Can I buy normal sensors from my local parts store or should i go to the dealer or what? Whats the best sensor to buy?
Old Feb 29, 2004 | 01:19 PM
cocheese's Avatar
Thanks for the replies guys! Any more useful info would be greatly appreciated! Keep it coming!
Ryan
Old Feb 29, 2004 | 01:23 PM
cocheese's Avatar
I would stick with the AC Delco's, for they worked much better than the Bosch ones i had in. Or at least lasted longer anyway!
Nov 18, 2023 07:21 PM
RUENUF
Mar 13, 2016 03:39 PM
jasonduaine
Apr 1, 2015 08:09 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
ModdedNerd
Jan 1, 2015 10:56 AM
