Hooker LT install!
Hooker LT install!
Hey guys, i'm finally in the process of installing my LT's, so i'll be back and forth on here w/questions i'm sure. First of all, i'm in the middle of removing the pass side exhaust manifold, do i need to remove the alternator to get it out?
Thanks,
Ryan
Thanks,
Ryan
You should already have heated O2s in your car so your stock ones will work. You will either have to cut and splice your O2 sensor wires or get O2 extensions to get them hooked up in their new location.
BUY BAND-AIDS!! Everything is sharp under these cars.
Other than that you should do ok.
Originally posted by carlos64030
Be prepared to jack the motor up...you may, or you may not have to.
Strange, eh?
Okay I have a question about the O2's too as I'm gonna be installing mine soon. Can I buy normal sensors from my local parts store or should i go to the dealer or what? Whats the best sensor to buy?
jasonduaine
Apr 1, 2015 08:09 PM
