piston not TDC when carnk pully at 12 0'clock
Old Feb 29, 2004 | 01:08 PM
Zack's Avatar
for the #1 piston to be completely TDC, the arrow points just a little past 12 0'clock. I dont know if it is for sure, since Im not lookin straight at it, but does this sound right?
Old Feb 29, 2004 | 01:14 PM
IrocSS85's Avatar
sounds like someone didnt have it straight up when they installed it. when I had mine apart, I used a chisel to make a line pointing straight up on the end of the crank while i had the timing dots perf. lined up. that will give me a easy way to make sure the hub is lined up while Im reinstalling it.
but, it wont hurt anything at all. they are neutrally balanced. it can be on there any position you want to put it on. the only reason I cared to mark it and reinstall it straight up is for lashing the valves.
chris
Old Feb 29, 2004 | 01:29 PM
Zack's Avatar
yea, im gonna need to set the lash when I get the heads on, thats why I asked
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
