hooker long tubes
Old Oct 23, 2004 | 12:52 AM
Zeueses 97 RamAir's Avatar
hooker long tubes
Ok I have hooker long tubes my number 5 wire is not even touching the header and causes my car to misfire burns thru the coating. What can I do..... thanks
Old Oct 23, 2004 | 01:03 AM
firetird's Avatar
Re: hooker long tubes
i would get some new wires. what kind are you running now? i used taylors for a long time but finally switched to accel 9000 wires. i like the accel's 10 times better. btw, i have hooker long tubes and i dont have any issues with wires.
http://store.summitracing.com/defaul...l+9000&x=0&y=0
Old Oct 23, 2004 | 02:33 AM
Boost It!'s Avatar
you love header wrap
Old Oct 26, 2004 | 02:42 AM
msd 8.5ss fixed it just angled it more away from headers
Old Oct 26, 2004 | 03:12 AM
dmoor88's Avatar
i would not use header wrap in any case.
Old Oct 26, 2004 | 07:47 AM
PatriotTA's Avatar
Agreed. You can mess with your wire routing, or get fire boots for the plugs, but I've heard too many negatives about header wrap.
Old Oct 26, 2004 | 12:39 PM
Bersaglieri's Avatar
Had same exact problem with 8.5s, had to run some extra firewire I had laying around to run the wire from the opti around the outside of the headers straight to the plug. Running it underneath just burns that #5 again and again...No problems since.
-Dustin-
Old Nov 1, 2004 | 12:34 AM
Boost It!'s Avatar
why is that? Header wrap does a much better job of insulating than ceramic coating does.
We had to make the switch in our turbo racecar because ceramic coating just wouldn't cut it. it really sucked
Old Nov 1, 2004 | 12:46 AM
Z-RATED94's Avatar
Header wrap has its place, but in most cases there are easier ways not to burn plug wires.
Old Nov 1, 2004 | 10:29 AM
will62085's Avatar
are you running them over the valve cover? have any pics?
Old Nov 1, 2004 | 01:35 PM
FIREHAWK #7's Avatar
A friend of mine has BBK's on his car, and also had trouble with one of his wires always getting burned, so he put header wrap around that primary... to me it smells like something is burning when you put header wrap around there, anyways he some how got oil on one of the wraps around the header and his engine bay caught on fire one night, good thing i had one of those small fire extinguishers on hand that night
Old Nov 1, 2004 | 09:01 PM
TheBiz's Avatar
I am running Hookers with the Taylor Over the Valve Cover Kit. I love them. The kit keeps the wires totally out of the way. I have pics on the website in the sig if you want to take a look. My car is the first one on the home page. Let me know what you think.
The farther you can get the wires away from the tubes, the better off you will be.
Good luck,
BIZ
Old Nov 2, 2004 | 12:35 AM
firetird's Avatar
sorry no pics, but the setup i have now is actually 7 of the accels and one custom made taylor. the taylor is on the #7 primary bc none of the accel's were long enough for me. i just ran the wires to where they wouldnt touch anything that would make the leak any electricity. its not the prettiest but it works.
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
Wicked
Aug 22, 2002 12:37 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
