hooker long tubes
Old Jun 13, 2003 | 07:08 PM
johnmon94's Avatar
hooker long tubes
I would like to chat with some people that have these for there LT1.I am wanting to buy a set but i have some questions,what do you do with your A.I.R. injection do the headers come with A.I.R. hookup?What about EGR tube hookup?Do you have to just unhook and block off everything and get custom programming?If so were do I go to get the parts I need at the best price?Any help would be great,thanks.
Old Jun 13, 2003 | 07:21 PM
1995redZ28's Avatar
i think you can get the hookers with all the emissions stuff, im not sure though. i ordered mine from Jet Hot with no emissions fittings. the AIR you basically remove. you will unscrew the fittings on the stock manifolds, and unbolt and remove the AIR pump. then i just used a dremmel to cut and remove the little pipe that goes under the timing cover from one side to the other. the EGR needs to be removed also. just unscrew the nuts holding the pipe that goes into the rear of the pass. side intake manifold. remove the pipe. then you will also remove the EGR valve which is on the rear drivers side of the manifold. then you will need to block off both holes with plates. i ordered my blockoff plates from
www.mycamaroz28.homestead.com steves a great guy, he will hook you up with what you need! thats really about it!!
oh and for programming the emissions out of the computer send your PCM to www.pcmforless.com !!! that way you wont have a SES light on.
Old Jun 13, 2003 | 08:09 PM
johnmon94's Avatar
Thanks for the info your help was great!
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
Wicked
Aug 22, 2002 12:37 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
