High volume oil pump
Old 04-23-2003, 06:52 PM
I burn rice too's Avatar
I got a high volume oil pump from Summit with the rebuild kit, but my stock pickup wouldn't fit, so Icalled Summit and asked if it was a special pickup or something. But the guy told me to send it back and get a stock pump becuse only going to the track once in a while it would do more harm than good becuse at high rpm's it would suck the oil pan dry. Does this make sense, has any one else heard of this?
I burn rice too is offline
Old 04-23-2003, 06:58 PM
Nobody has a high volume pump?
Old 04-24-2003, 05:22 AM
badass383's Avatar
I have not heard that one but I agree none the less that SBC's have a good oil pump and you should not use a high volume unless you are running real high RPM's.
The high volume puts all the oil at the top half of the engine and thus heats it up too much. I guess then if you think about it he could be right. But I just avoided it altogether. BTW weld your pickup on. Be sure to remove the pressure relief before you do so the heat of welding doesn't destroy it. Use the type of pickup that has the bracket that bolts to the pump so you have 2 points of strength.
badass383 is offline
Old 04-24-2003, 02:47 PM
Z28SORR's Avatar
Yes! Take their advice or get a high volume pan.
Z28SORR is offline
HectorM52
07-30-2017 11:46 AM
HectorM52
06-23-2016 08:42 PM
DirtyDaveW
03-15-2015 07:01 PM
carl.froehlich
03-13-2015 12:38 AM
Hoodshaker
08-27-2002 02:32 PM
Quick Reply: High volume oil pump
