High Idle
Old Mar 7, 2015 | 07:52 PM
1996LT1Z28's Avatar
High Idle
When I start my car for the first time in the morning when cold, the idle stays high (1000 rpm), then goes down to 800 rpms after the engine warms up.
Does this sound normal?
Old Mar 7, 2015 | 09:29 PM
94Z28LS1toLT1's Avatar
Re: High Idle
that sounds fine to me... mine does that too and will go to 900 and stay there perfect unless im wrong
Old Mar 7, 2015 | 10:30 PM
Re: High Idle
You indicate you have an auto trans. Apparently you swapped the gears to have 3.42's. Stock idle programming fully warmed up is 650 RPM in neutral, and 550 RPM in gear. Stock tach can read 100 - 200 RPM above actual engine RPM. Put a scanner on the PCM to get the true idle speed.
The PCM is programmed to raise the idle on cold start, based on coolant temp. It can go as high as 1,200 RPM with sub-0°F temps. Idle speed will drop gradually as coolant warms up.
Old Mar 7, 2015 | 10:32 PM
Re: High Idle
Can't compare. Programmed idle is higher for the M6.... 800 RPM fully warmed up.
Old Mar 8, 2015 | 08:16 PM
Re: High Idle
lol didnt read his signature until now,when i start mine up it will idle like 900 or 1000 then after warm up will go to 800-850. thank you for the information
blac94Z
19
May 13, 2015 04:50 PM
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
