High Idle
Old Nov 13, 2014 | 09:47 PM
kodalee's Avatar
High Idle
I have a 93 lt1. when its cold it idles around 600-800 as soon as it gets warm it idles around 1800-2000. I have fixed the wiring around the map sensor, the iac sensor, the tps sensor and the iat sensor. I have cleaned the iat sensor, the iac sensor and the throttle body. I have also replaced the tps sensor. what can be causing this problem?
Old Nov 14, 2014 | 07:01 AM
Re: High Idle
Which trans, auto or manual - determines what the correct idle speed should be?
When the coolant is cold, the ECM raises the idle speed. If "cold" is, for example, 24*F, idle speed should be 800 RPM for an A4 in gear, 1,000 RPM or an A4 in neutral and 1,000 RPM for an M6. The stock tach typically reads 100-200 RPM above actual idle speed. Since the ECM looks at coolant temp to set idle speed, a faulty CLT sensor could cause a problem.
Idle is controlled by the ECM, using the idle air control motor (IAC is not a "sensor"). If the IAC motor is faulty, or the harness circuits are faulty, the ECM can't control the idle. There are no DTC codes for a faulty IAC. Here's a method to check the IAC (93 will be similar to 95):
http://shbox.com/1/iac2.jpg
Have you scanned the ECM for codes:
http://shbox.com/1/dlc2.jpg
Have you checked the throttle cable/linkage to make sure it isn't hanging open when the engine heats up?
Old Dec 29, 2015 | 09:57 AM
Re: High Idle
Wouldn't if be nice if once in a while people would come back and post to acknowledge that they even read the answer....... maybe note whether they were able to solve their problem??????
Total lack of courtesy.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
