High idle?
Old Jul 15, 2004 | 02:04 PM
  #16
Another thing.....
IAT signal = pin C21
MAP signal = pin C23 (ref volts and ground are on connector B)
IAC driver circuits = pins C1, C2, C5, C6
O2 high low signals = pins C7, C8, C19, C20
Are we beginning to see a pattern here?
Old Jul 15, 2004 | 02:06 PM
  #17
Pasky's Avatar
Originally posted by Injuneer
Another thing.....
Indeed, i'll check my PCM plugs for the C connector, also any grounds it gets on that connector, thanks for the help. I didnt have time to look last night as it was already night fall. I work until 9PM, I get most of my wrench time on the weekends.
Old Jul 15, 2004 | 05:45 PM
  #18
Pasky's Avatar
Thank you very much injuneeer, im home for a short break and decided to check out the PCm plugs. The whole gray connector was unplugged . They shoved my PCM under the new carpet. . Im amazed the computer was running without that plug. Thank you very much, problem solved.
Old Jul 15, 2004 | 11:13 PM
  #19
Thanks for the feedback. I should have thought of that right up front.... but glad I was able to help you track it down.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
