High Flow cats...
Old May 11, 2004 | 01:08 AM
  #16
CeeBee94Z's Avatar
Originally posted by toegead93
Car Sound 93441 is a direct replacement for 1993-95 Camaro & Firebird with the 350 LT1 engine. The converter has a 3" inlet and is flanged at the back (3") to connect to your stock or aftermarket cat-back exhaust system.
Check out racenet.net:
http://www.lt1f-body.racenet.net/mufflers.php
I'd send it to you for $100 +shipping.(UPS is $8.60 to Troy)
Ok let me figure out my financial situation, I may have to see how big my paycheck is on friday but I am definitely interested. I will let you know as soon as I figure out my situation.
Thanks again
Old May 11, 2004 | 08:49 AM
  #17
stereomandan's Avatar
Originally posted by Stoopalini
That is what is called a 3 way plus oxidation converter. It seems to be a cat they are trying to say is good for any Camaro or Firebird?
The added tube sticking out the side is for air to be injected in between the bricks. Newer cats are more efficient and do not require the added oxygen to be injected. Seems to me someone has a surplus of old cats hanging around and is selling them on e-bay as universal cats. Remember, you get what you pay for ... platinum is not cheap, so for $35, they definitely had to save $$ somewhere in the design..
Our cars do not use a smog pump that injects oxygen into the cat ... the smog pump in our cars pumps air into the manifolds until the motor gets hot enough to allow the bricks in the cats to start performing the catalyst process; then the A.I.R. pump shuts off.
Thomas.
Just for refrence, the cat that I recommended, the 94109, does not have the smog hookup. It does not need it. I think they have the smog pipe welded on other models so that on an older car, you can still hook it up if you want to.
My universal Carsound 3" in/out has no pipe, and flows good, and the quality was excellent. I don't know if there is any less platinum in the Carsound cats, but they serve my purpose for putting one in. (Less Rasp, less noise, less popping, and less exhaust smell) We don't have emmisions testing in my area.
Dan
HectorM52
Jun 23, 2016 08:42 PM
TitoPR221
May 26, 2015 12:20 AM
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
CeeBee94Z
Jul 31, 2002 02:20 PM
