Hesitation under Medium Acceleration. Fuel Pump Going Bad? Help!
Old Aug 7, 2005 | 09:46 AM
scmudslinger's Avatar
I noticed recently after running my car hard for a while, say 100 mph for a few miles, after I come to a stop and go to accelerate, if I give it about 30% throttle or more, it starts off to accelerate, then hesitates like it's trying to go, but it sits there for a few seconds jumping and hesitating. Also, one time after I ran it down an 1/8 mile track, it cut off after I let out of the throttle and then started back up on its on. Also, one time after I ran it hard for a while, it cut off under medium acceleration from a dead stop, and then upon cranking back up, took about 3 seconds to fire before it started. Could a fuel pump going bad cause this? Please help.
1993 Chevrolet Camaro Z28 --- Automatic
Moroso Cold Air Intake
Jet Stage-1 Chip
Old Aug 7, 2005 | 09:56 AM
BlackDog's Avatar
Re: Hesitation under Medium Acceleration. Fuel Pump Going Bad? Help!
Try cleaning your MAP sensor. Remove it and shoot some carb or brake cleaner in the whole in the sensor.
When was the last time you changed the o2 sensors?
Do you have an aftermarket fuel pump? If not, I doubt it's the pump.
Try cleaning the tb an iac.
Old Aug 7, 2005 | 10:00 AM
What is your MAP Sensor? Also, I don't think my Oxygen Sensors have ever been changed. Also, what was that last thing you said?
"Try cleaning the tb an iac"
By the way, my fuel pump is factory.
Old Aug 7, 2005 | 11:32 AM
TA2PLAY's Avatar
Try cleaning the throttle body and idle air control valve. Both can be found on shoeboxes website, do a search for it.
Old Aug 7, 2005 | 08:03 PM
BlackDog's Avatar
Sent you email via hotmail.
Old Aug 11, 2005 | 08:25 PM
BlackDog's Avatar
How about an update?
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
